1990 ford probe lx wire diagram
panama red
Posted: January 31, 2003 at 11:06 PM / IP Logged
I need a wire diagram to hook up a car alarm with remote start,and keyless entry,and i would also like to hook up my remote to open my trunk
jayts95
Copper - Posts: 150
Posted: February 01, 2003 at 6:58 PM / IP Logged
|              12V|blk/blu or black    |+  |steering column             |
|          STARTER|blk/yel or blk/red  |+  |steering column             |
|         IGNITION|blk/wht or blk/yel  |+  |steering column             |
|  SECOND IGNITION|                    |   |                            |
|        ACCESSORY|blk/red or blue     |+  |steering column             |
|       POWER LOCK|GREEN/ black         |*1 |driver kick panel           |
|     POWER UNLOCK|same wire           |   |                            |
| PARKING LIGHTS +|RED / black           |   |at dimmer switch            |
| PARKING LIGHTS -|RED / yellow          |   |at headlight switch         |
|       HEADLIGHTS|WHITE/ yellow       |-  |at headlight switch         |
|     DOOR TRIGGER|RED / WHITE/ sil dot  |-  |lower drivers kick          |
|  TRUNK/HATCH PIN|red                 |-  |at rear light               |
|         HOOD PIN|RED / white           |+  |sw or light under hood      |
|       TACHOMETER|yellow/blue         |   |coil or diagn. plug         |
|       BRAKE WIRE|WHITE/ green         |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN/ orange        |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|RED / blu - grn/blu   |A  |in drivers door             |
|  RF WINDOW UP/DN|grn/wht - RED / wht   |A  |in drivers door or dkp      |
Notes:
*1 Lock requires a positive trigger. Unlock requires a positive trigger through a 4,700 ohm resistor. Must use relays for both lock and unlock.
panama red
Posted: February 07, 2003 at 1:00 PM / IP Logged
would it be possible for someone to post a step by step guide for a car alarm keyless entry ,remote start for a 1990 ford probe,i have the unit but not the cash to pay for a pro install any help would be appreciated1990 ford probe lx wire diagram  -- posted image.
