07 Ford Edge, autolamp feature?
Mike M2
Platinum - Posts: 2,652
Posted: January 18, 2007 at 8:18 PM / IP Logged
One of my guys did one today, real easy car. The thing has a wierd parking light wire tho. According to Avox, you need to split a wire if it has  the Autolamp feature. Problem is, we couldn't tell if it did or not! Has anybody else done one?
Mike M2
Tech Manager
CS Dealer Services
NowYaKnow
Gold - Posts: 1,217
Posted: January 18, 2007 at 9:56 PM / IP Logged
Nothing different than most other fords from about 05+. And from the 08's probably the whole lineup. Anytime you use the negative park lights on them you need to split your output to relays in order to bypass the auto lights. If you don't no big deal just the lights won't flash if the customer leaves the switch in the auto position. Don't mess with that just hit the positive lights and your good to go. Should be in the driver door sill I'm thinking blue/white (+) like a newer explorer. Worst case pull one of the taillights and see what color the park light wire is and find that in the door sill.
Mike
mikvot
Gold - Posts: 1,043
Posted: January 20, 2007 at 10:53 PM / IP Logged
On the edge....positive park light is violet/white at kick
Mike M2
Posted: January 21, 2007 at 7:44 AM / IP Logged
Thatnks, i'll try that next time...
Mike M2
Tech Manager
CS Dealer Services
