06 Sienna factory remotes while running?
csorb
Copper - Posts: 317
Posted: January 26, 2007 at 1:30 AM / IP Logged
Hi. I have been told that there is a way to allow the factory remote to work even once the car is running.(we did a one button remote starter) Has anybody done this or have info? Thanks
mobilecustoms
Silver - Posts: 397
Posted: January 26, 2007 at 5:44 AM / IP Logged
toyotas cant use factory remotes when running.
Chris Luongo
Platinum - Posts: 3,746
Posted: January 26, 2007 at 6:24 AM / IP Logged
Already tried it on a Sienna.
I found one wire at the BCM I could interrupt, and then the keyless did work.......but I also got all kinds of warning lights on the dash, and it also killed the climate controls, so that isn't going to fly.
One-button remote starters are a lousy idea on Japanese cars.
Mike M2
Platinum - Posts: 2,652
Posted: January 26, 2007 at 6:40 AM / IP Logged
Now i wouldn't say all Jap cars, Nissans still work if they are running....
Mike M2
Tech Manager
CS Dealer Services
KarTuneMan
Platinum - Posts: 7,056
Posted: January 26, 2007 at 8:19 AM / IP Logged
Japanese....Japanese..... come on, be a bit P.C.    06 Sienna factory remotes while running? -- posted image.
This coming from a Russian Jew.......06 Sienna factory remotes while running? -- posted image.
Mike M2
Posted: January 26, 2007 at 6:05 PM / IP Logged
Hehehe, sorry for the Bill Parcells type comment. You can call me a Pol if ya like....
Mike M2
Tech Manager
CS Dealer Services
concepts99
Member - Posts: 24
Posted: January 27, 2007 at 9:00 PM / IP Logged
Does anyone know if the inputs for the sliding doors and trunk with an AFTERMARKET negative pulse will still work after the Sienna is remote started?
mobilecustoms
Silver - Posts: 397
Posted: January 28, 2007 at 8:19 AM / IP Logged
with an aftermarket remote- yes
factory remote will not work
Mike M2
Posted: January 28, 2007 at 9:39 AM / IP Logged
The override switch under the dash has to be plugged in and turned on, but the pulses will open and close them all....
Mike M2
Tech Manager
CS Dealer Services
csorb
Copper - Posts: 317
Posted: January 28, 2007 at 1:27 PM / IP Logged
Thanks everybody. My customer walked into a shop who told him that they could do it and whoever put in the system was second class. Maybe they were just talking big...maybe not. Mike what did you mean by the overide switch?
