wiring multiple relays together?
puredrifter
Posted: January 29, 2007 at 1:41 AM / IP Logged
ive been looking thru previous posts but havent been able to find anything similar to what i need.
i have Four (4) SPDT relays which im attempting to set up so that all 4 turn on from 1 switch. they are being used to switch +/- audio signals L and R between 2 sources.
wiring multiple relays together? -- posted image.
currently i set up the relays with the 85 terminal of 3 connected to the 86 of eachother, with an 85 on the first open and the 86 of the last open. (basically in series)
this is my first attempt at using Multiple relays so any help would be greatly appreciated.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 29, 2007 at 9:51 AM / IP Logged
Your trying to use relays to switch audio signals......can't be done. Unless you have miss typed your post. Or I don't understand....?
puredrifter
Posted: January 29, 2007 at 1:37 PM / IP Logged
each one of the 4 relays controls a single polarity of L or R audio.
IE. the 30terminal is the line going to the HU preamp input (either L=, L+, R-, or R+) with the 87a and 87 terminals being preamp outputs from 2 separate audio devices. the way i have it set up is that the signal is basically switched between them depending on whether the relays are energized or not.
i have this working with 2 independantly wired relays on a test 12v supply but i have no idea how to make all 4 energize the coil at the same time. im fairly sure that the daisy chain i have right now isn't correct.
the12volt
Administrator - Posts: 3,959
Posted: January 29, 2007 at 1:48 PM / IP Logged
Disconnect what you currently have connected in the above image.
Actually it can be done with relays. Connections are as follows:
Relay 1
30 : Left (-) out
87a: Left (-) source A
87 : Left (-) source B
85 : negative from switch
86 : 12V+
Relay 2
30 : Left (+) out
87a: Left (+) source A
87 : Left (+) source B
86 : 12V+
Relay 3
30 : Right (-) out
87a: Right (-) source A
87 : Right (-) source B
86 : 12V+
Relay 4
30 : Right (+) out
87a: Right (+) source A
87 : Right (+) source B
86 : 12V+
wiring multiple relays together? -- posted image. the12volt • Support the12volt.com
the12volt
Posted: January 29, 2007 at 1:53 PM / IP Logged
BTW, I'd add a 1 amp diode across the coil of each relay with the cathode side connected to 86 and the anode side to 85.
puredrifter
swo basically i should wire the coils up in parallel instead of in series as i have above?
the12volt
Posted: January 29, 2007 at 1:54 PM / IP Logged
Correct. Wiring them in series will not accomplish anything.
puredrifter
Posted: January 29, 2007 at 1:57 PM / IP Logged
thanks for the help everybody, one last question for you all :)
any wiring tips on connect 4 wires together from common power wire wiring multiple relays together? -- posted image.
the12volt
Posted: January 29, 2007 at 2:07 PM / IP Logged
If it's for this application, you can solder each of the respective coil leads together with one lead coming off of one terminal to connect to your power source.
puredrifter
Posted: January 29, 2007 at 2:32 PM / IP Logged
kinda like that? sorry, but ur post was a bit hard to understand for me.
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
