2007 civic 2 door, micu
hanhpham2k
Member - Posts: 15
Posted: February 04, 2007 at 8:35 PM / IP Logged
please help me , i have a clifford rs3.5 alarm . i need to know there is a wire saids h1/6  blue wire on the installation , where do i hook this wire to in the car ,. and also i can remote start the car but it won't run and keep on restarting again and again ...please help me ...thank you
KarTuneMan
Platinum - Posts: 7,056
Posted: February 04, 2007 at 10:39 PM / IP Logged
Use your multi-meter.....pierce the wire, then hit the trunk release on the factory remote....the wire will pulse POS(+)
Did you get your bypass module, like the guys said back a couple posts??? The blue wire your trying to find out what to do with is the ground while running. It's used to "turn on" the module, so your car will start.
