457gw, 2000 pontiac grand am
maple75
Posted: February 04, 2007 at 5:42 PM / IP Logged
I have a 2000 pontiac grand am gt. i recieved a valet 561r remote start and 457gw interface for xmas. the problem i'm having is there is no install paper or diagram with the 457gw. i have also heard that the 457gw will not work the power locks. can anyone help me?
Twelvoltz
Platinum - Posts: 2,384
Posted: February 04, 2007 at 9:27 PM / IP Logged
DEI lists this info for your 00 Grand Am.
DIRECTWIRE™ WIRING INFORMATION - PONTIAC / GRAND AM / 2000 / Remote Start
[PRINT THIS PAGE]
12volts      red       +       ignition harness
Notes: Remove the radio, without unplugging it, to access the ignition harness.
Starter      yellow       +       ignition harness
Second Starter
Ignition      pink       +       ignition harness
Second Ignition      dk. green       +       ignition harness
Third Ignition
Accessory      orange       +       ignition harness
Second Accessory      brown       +       ignition harness
Keysense
Power Lock      white       -       black plug in dkp
Notes: Lock requires a negative trigger, and unlock requires a negative trigger through a 1,500 ohm resistor. Must use relays. Must close doors to lock with a single pulse.
Power Unlock      same wire
Lock Motor      gray             drivers kick panel
Unlock Motor      tan             drivers kick panel
Parking Lights+      brown             passenger kick or column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger            -
Notes: The lt. GREEN/ black is located in the drivers kick and catches only the drivers door. The lt. blue is located in the harness coming from the drivers running board going under the drivers seat and it catches all other doors. Use both door trigger wires and diode isolate each. On the 2 door the lt.blue is in the passenger kick.
Dome Supervision      white       -       dash light or column
Trunk/Hatch Pin      ORANGE / black       -       trunk light
Hood Pin
Trunk/Hatch Release      BLACK/ white       -       trunk release switch
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer      white or PURPLE / wht             ignition coil or ECM
Notes: The ECM is located under the left side of the dash to the left of the column.
Wait to start
Brake Wire      lt. blue       +       at the switch
Parking Brake
Horn Trigger      black       -       steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Passlock II
Part #: 1100F
Alternate Part1 #: 1100X
Alternate Part2 #: 556LW
Alternate Part3 #: 555LW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: When using the 1100F or 1100X, a software change to 1100GM is needed.
Door Lock Interface      Required:
Yes      Type:
Multiplex
Part #: 456LW
Notes:
Combo Interface      Required:
Yes      Type:
Data Bus
Part #: 1700G
Alternate Part1 #: 457GW
Notes: Can use the 1700G or 457GW to bypass the Passlock II, but it will not control the door locks on this model year.
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
As you can see the 457 will work for bypassing the passlock, but will not do the door locks on your vehicle. You can grab the install manual here.
maple75
Posted: February 05, 2007 at 8:15 AM / IP Logged
what do i need to work the door locks
lsondubz
Copper - Posts: 193
Posted: February 05, 2007 at 8:41 AM / IP Logged
Either have to use relays and resistors or a resistance learning lock module if you want
maple75
Posted: February 05, 2007 at 10:12 AM / IP Logged
any particular brand
Twelvoltz
Posted: February 05, 2007 at 12:06 PM / IP Logged
For door locks you can pick up a DEI 451M it comes with the required resistors and plugs right in to the door lock port on your 561R. You can find these on the web for less than $10.
kgerry
Platinum - Posts: 3,455
Posted: February 05, 2007 at 1:58 PM / IP Logged
or a 456L if you dont want to mess around with relays and resistors....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
maple75
Posted: February 05, 2007 at 8:26 PM / IP Logged
do i still need the 457gw with those
Mike M2
Platinum - Posts: 2,652
Posted: February 05, 2007 at 8:40 PM / IP Logged
Yes, you need it to bypass the PK3 for it to remote start. You will only connect 4 wires on the 457G, black, red, blue and purple(no others!)
Mike M2
Tech Manager
CS Dealer Services
maple75
Posted: February 05, 2007 at 9:22 PM / IP Logged
where does the blue wire hook up to?
