Clifford concept 300 aux outputs
JohnnyD
Posted: February 03, 2003 at 1:20 PM / IP Logged
I wonder if anyone can help me?
My mate has a clifford concept 300 and i am designing a circuit to run some stuff off one of the accessory channels (ie: when he presses a button on the remote, my circuit comes into play) but i need to know:
What is the voltage out of these things? i have been told it's +3v - if so, can you ground it to the car body or not?
I would have thought it was either +12v or just a ground switch.
Cheers.
10nesne1
Silver - Posts: 284
Posted: February 04, 2003 at 1:14 AM / IP Logged
Well, the aux output from Concept 300 are 500mA Negative output and it required a relay to hookup to your circuit.
cva2000uk
Copper - Posts: 60
Posted: February 04, 2003 at 2:15 AM / IP Logged
and if you want a diagram for it you can get it from clifford's web site.
download the wiz software onto ur laptop and buy the wizard lead.
this makes life allot easierClifford concept 300 aux outputs -- posted image.
"you wont like me, when i get angry" .
JohnnyD
Posted: February 04, 2003 at 3:34 AM / IP Logged
the clifford website hasn't got the concept 300 diagrams on there. My mate said he measured the voltage out and it was +3v so why would this be if it is a negative switch?
If it is a negative switch, do i take a +12v supply through the relay coil back into this aux switch and use the relay contacts for the circuit???
Cheers lads.
