wiring for a 2006 suzuki grand vitara xl7
shoks
Posted: February 08, 2007 at 11:20 AM / IP Logged
I want to install a GSM monitored immobilizing alarm, so I need the wiring diagram for the ignition etc.
Any help?
Twelvoltz
Platinum - Posts: 2,384
Posted: February 08, 2007 at 11:38 AM / IP Logged
DEI lists this for the US version:
DIRECTWIRE™ WIRING INFORMATION - SUZUKI / GRAND VITARA / 2006 / Remote Start
[PRINT THIS PAGE]
12volts      wht/red (50A), wht/grn (40A)       +       ignition harness
Starter      BLACK / YELLOW       +       ignition harness
Second Starter      N/A
Ignition      BLACK / YELLOW       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      yellow       +       ignition harness
Second Accessory      blue       +       ignition harness
Keysense      blue/red       +       ign harn or BCM, 24 pin plug, pin 3
Notes: The BCM (Body Control Module) is above the driver kick panel.
Power Lock      pink/black       -       dr kick or BCM, 40 pin plug, pin 27
Power Unlock      pink/green       -       dr kick or BCM, 40 pin plug, pin 26
Lock Motor      blue/red       5wi      dr kick or BCM, 15 pin plug, pin 3
Unlock Motor      blue       5wi      dr kick or BCM, 15 pin plug, pin 8
Parking Lights+      RED / yellow       +       driver kick or fuse box, 24 pin plug
Parking Lights-      RED / blue       -       switch or BCM, 24 pin plug, pin 11
Hazards      yellow/red       -       switch or BCM, 40 pin plug, pin 34
Turn Signal(L)      GREEN/ red       +       driver kick or fuse box, 24 pin plug
Turn Signal(R)      GREEN/ YELLOW       +       driver kick or fuse box, 24 pin plug
Reverse Light      red       +       driver kick, harness to rear
Door Trigger      BLACK/ org (D), BLACK/ red (P)       -       DKP or BCM, 40 pin plug, pins 39, 38
Notes: Use both wires and diode isolate each.
Dome Supervision      BLACK/ red       -       A pillar or BCM, 15 pin plug, pin 15
Trunk/Hatch Pin      common with pass. door trigger
Hood Pin      N/A
Trunk/Hatch Release      blue/white (unlock only)       5wi      pass kick or BCM, 15 pin plug, pin 7
Power Sliding Door      N/A
Factory Alarm Arm      pink       -       dr kick or BCM, 40 pin plug, pin 37
Notes: Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm      pink/blue       -       dr kick or BCM, 40 pin plug, pin 36
Disarm No Unlock      see factory alarm disarm
Tachometer      NOT blk/wh, blk/org or blu/blk      ac       any ignition coil or fuel injector
Wait to start      N/A
Brake Wire      GREEN / WHITE       +       brake pedal switch or driver kick
Parking Brake      RED / black       -       switch or BCM, 40 pin plug, pin 8
Horn Trigger      blue       -       switch or BCM, 40 pin plug, pin 15
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Sunday, October 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
