alarm keeps chirping.
gms81
Member - Posts: 47
Posted: February 23, 2007 at 8:10 PM / IP Logged
I just installed a code alarm ca670 on my 2006 dodge ram and everything is working fine except after arm it after a few minutes or someitmes an hour or so it chirps 5 times (warning chirp). I used the chdlpk2 bypass module. I cut the input trigger to the brain to see if that was the problem but it still does it. What could be causing this? I have checked and double checked all my connections and everything is fine.
mikvot
Gold - Posts: 1,043
Posted: February 23, 2007 at 8:44 PM / IP Logged
Try turning the sensitivity down a little, and see what happens. Could just be a bad shock sensor, but i doubt it. I use code and have never had a bad shock. What input trigger did you cut, the shock sensor input?
gms81
Member - Posts: 47
Posted: February 23, 2007 at 11:18 PM / IP Logged
I cut the input for the door trigger thinking maybe it needed to be diode isolated. The shock sensor is built in on this unit. I tapped on the window to check its sensativity and it seems normal, maybe a bit sensative but not too bad. I will give it shot anyway.
mikvot
Gold - Posts: 1,043
Posted: February 23, 2007 at 11:28 PM / IP Logged
yeah, your door trigger shouldnt cause it to chirp 5 times...... that trigger would be instant and would cause the alarm to fully trigger.
concepts99
Member - Posts: 24
Posted: February 24, 2007 at 4:09 PM / IP Logged
Disconnect the shock sensor and test, if it doesnt make any noise, you know it is the shock sensor or the setting,
gms81
Member - Posts: 47
Posted: February 25, 2007 at 3:24 PM / IP Logged
Since the shock sensor is built in I dont know if I can disable it but I will turn it all the way down and see what happens.
gms81
Member - Posts: 47
Posted: February 28, 2007 at 10:17 PM / IP Logged
Ok, update. I turned the shock sensor way down and it fixed the problem. I didnt think this was it because I had to hit the front pillar of the truck to get it to chirp, maybe something clicks under the dash or something, I dont know and dont care...problem solved. Thanks for the help.
