Posted: April 06, 2007 at 12:59 PM / IP Logged
Posted: April 07, 2007 at 2:29 AM / IP Logged
Posted: April 09, 2007 at 9:48 AM / IP Logged
Posted: April 09, 2007 at 10:20 AM / IP Logged
Posted: April 09, 2007 at 7:14 PM / IP Logged
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
This assumes the microswitch is set up to be in the Normally Open position when the limit is reached, and NC otherwise.changed the ground control for the relays to use the opposing side relay to prevent a situation where both relays can get energized if the control is hit while already moving, stopping the motor from traveling to the limits.
