backup camera trick?
gc714
Member - Posts: 32
Posted: March 06, 2007 at 5:22 PM / IP Logged
Hello all,
I searched with no luck. I imagine if it's possible to be done the knowledge in on this site :D
I have a new backup camera from ebay and also have my Pioneer avh p5700 combined with an avic 80 navi.
What I would like to do is wire in the camera as normal so that it automatically turns on when in reverse, but the trick part would be to be able to turn it on whenever I want as well, even when not in reverse. It would be cool when sitting at a red light or something.
Is it possible, maybe with a  12+ switch diode isolated with the reverse wire?
Thanks guys!!!
Ravendarat
Platinum - Posts: 2,806
Posted: March 07, 2007 at 1:12 AM / IP Logged
Ya here ya go. You need a standard 5 pin relay. Hook up pin 87a to the back up light wire in the vehicle, pin 30 to the back up camera pin 87 to 12 volts, pin 85 to 12 volts and pin 86 to a switch and the other side of the switch to ground and your done.
gc714
Member - Posts: 32
Posted: March 07, 2007 at 5:24 AM / IP Logged
Excellent, what about the wire to the in dash monitor?backup camera trick? -- posted image.
gc714
Member - Posts: 32
Posted: March 07, 2007 at 5:52 AM / IP Logged
maybe 85 goes to the monitor?
spyderbyte
Member - Posts: 25
Posted: March 07, 2007 at 4:10 PM / IP Logged
Pin 30 connects to the monitor wire. How the circuit works: (if I understand it correctly)
When the switch is off, pins 87a and 30 are connected. The screen control is connected to the reverse wire. When the wire is energized (in reverse) 12v is sent to the screen to turn it on/switch to reverse view (whichever it does)
When the switch is on, pins 87 and 30 are connected, and 12 volts will be sent to the screen control.
Spyderbyte
gc714
Member - Posts: 32
Posted: March 07, 2007 at 8:21 PM / IP Logged
Hahaha, I guess I'm running short on cylinders.....The camera has 1 pos, 1 neg, and a single rca. The monitor receives the single rca and has a reverse signal input wire that attaches to the back up light. Obviously grd. the neg, pos. goes to pin 30, but does pin 87a t-tap the signal input wire  as it goes to the back up lights?
Can someone please hold my hand on this one? Lol backup camera trick? -- posted image.
spyderbyte
Member - Posts: 25
Posted: March 08, 2007 at 3:33 PM / IP Logged
That should do the trick.
Spyderbyte
gc714
Member - Posts: 32
Posted: March 09, 2007 at 5:45 AM / IP Logged
Excellent!! Thanks for the help guys!!! This Sunday I should have the free time for the install
Mike M2
Platinum - Posts: 2,652
Posted: March 10, 2007 at 1:19 PM / IP Logged
What turns the camera on is 12 volts on the reverse wire on the AVIC. Simply run a positve thru a switch, then tie it to the reverse wire on the AVIC. Place a diode in the wire coming from the reverse signal, band towards the AVIC, so the switch won't backfeed to the lights in the car.
Mike M2
Tech Manager
CS Dealer Services
gc714
Member - Posts: 32
Posted: March 10, 2007 at 6:19 PM / IP Logged
Alright Gents!!! Talk about the cart before the horse!! I went out this evening to start the install since tomorrow I'll have limited time. Decided to power up the cam to verify it indeed works, realized I had to initiate it in the menu on my in dash unit and found out it has an input setting to see the video from the camera without needing a separate switch! Lol
I'll post back as I complete the install...Thanks for the help!! Greg
