dome light supervision output
ren_l
Posted: March 12, 2007 at 6:35 PM / IP Logged
i have a 91 acura integra with nothing power "windows -doors" .i want to install my Radiostar generation two way alarm but as far as i know i only have one wire to the dome light and i dont know weather i should connect the negative door trigger the positive door trigger or the dome light supervision cord to this wire.
jjj
KarTuneMan
Platinum - Posts: 7,056
Posted: March 12, 2007 at 6:41 PM / IP Logged
You can use the dome wire without any problems. For both door trigger and dome supervision.
ren_l
Posted: March 12, 2007 at 6:48 PM / IP Logged
so what you are saying is to connect all 3 wires to the dome wire?what exacly dose that dome supervision wire do?
I wont drink and drive its bad
jjj
KarTuneMan
Posted: March 12, 2007 at 7:04 PM / IP Logged
your door trigger is negative so attach your neg door trigger INPUT to the negative dome wire. Also attach the NEG(-)  domelight supervision wire to this one as well. It turns the dome light on when you disarm. you can use this wire.
DOORPIN GREEN/ red In driver's kickpanel   -
ren_l
Posted: March 12, 2007 at 7:10 PM / IP Logged
thanks a million my head was gonna explode .lots of good karma going ur way
jjj
Twelvoltz
Platinum - Posts: 2,384
Posted: March 12, 2007 at 7:48 PM / IP Logged
You do not need to connect the positive door trigger at all. This wire allows the system to fit more than one type of vehicle. Your vehicle uses negative trigger so just use that one and cap off the positive trigger wire.
You may need a relay for the dome light supervision to operate. I know the DEI systems I deal with do not have enough of an output to run the light bulb in most vehicles from that era. Does your Radiostar unit list an internal relay for supervision or does it just list a 200ma output? If it has the internal relay then you will not need anything extra, if it does not you will probably need a relay.
KarTuneMan
Posted: March 12, 2007 at 9:42 PM / IP Logged
Read my sig..... I need the good karma. Thanks
