amplifier/subwoofer wiring
envoyxl
Member - Posts: 14
Posted: March 17, 2007 at 2:54 AM / IP Logged
Amp-2 channel monoblock MTX 1501D
Speaker-Kicker 10" L5 DVC 2ohm
Can I wire one voice coil to the left channel of my amp, and teh other voice coil to the right channel since the amp is run in mono. If not , why, and what can I do?
jmelton86
Gold - Posts: 1,228
Posted: March 17, 2007 at 8:04 AM / IP Logged
Looks like you'd have to hook each vc of the speaker up in parallel to the amp. You'd be getting 750wrms @ 4Ohms. If the amp has 2 separate speaker connections, 1 vc to each. This would still yield 750wrms @ 4Ohms, aprox. 375wrms to each vc.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
jmelton86
Gold - Posts: 1,228
Posted: March 17, 2007 at 8:05 AM / IP Logged
Sorry... Yeah, you had it right.
Big3 in 1/0G
1/0G to GTO14001
aznboi3644
Gold - Posts: 2,600
Posted: March 17, 2007 at 10:16 AM / IP Logged
Your amp has ONE channel...there are NO left or right channels.
Wiring each coil + to + and - to - the amp will be seeing 1 ohm.
if you wire the sub in series then to the amp the load will be 4 ohms
jmelton86
Gold - Posts: 1,228
Posted: March 17, 2007 at 2:15 PM / IP Logged
doodie, I was thinking of something else at the time. Disregard what I said and apply what aznboi3644 said, unless the amp isn't 1Ohm stable. In that case you'd have to load it at 4Ohms (sigh). (Single)Dual 2Ohm woofers aren't for 1 channel amps unless they're 1Ohm stable.
Big3 in 1/0G
1/0G to GTO14001
jmelton86
Gold - Posts: 1,228
Posted: March 17, 2007 at 2:17 PM / IP Logged
But I used an * instead of an i. Like, whatever.amplifier/subwoofer wiring - Last Post -- posted image.
Big3 in 1/0G
1/0G to GTO14001
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
