lastest build, mtx mzs1204, ps2-520
aznboi3644
Gold - Posts: 2,600
Posted: March 20, 2007 at 6:03 PM / IP Logged
Hey whats up guys...I like to build boxes as a hobby. This is my 8th box I think. It is an ABC/Dual-chamber bass reflex for one 12 incher. Main chamber is tuned to about 30Hz while second chamber is tuned to about 42Hz.
The subwoofer is an MTX MZS1204 powered by a Power Acoustik PS2-520 feeding it 300 watts.
Hows it sound you may ask?? Well for comparison the sub was in a 1 cu ft sealed box while for a couple weeks while I found time last weekend to finish building the box. The sealed box sounded tight and clean...BUT seriously lacked in output. The lows were weak and the higher bass notes were alright.
This is my first ABC box I've designed and built. It seriously SURPRISED me. The bass is still tight and even smoother now. The output is crazy for one 12 and 300 watts. This box slams the lows. With the car all sealed up and trunk closed my garage door and outside overhangs were rattling.
I got a couple vids and some pictures for you guys...Tell me what you think...good or bad I don't care, just some feedback
lastest build, mtx mzs1204, ps2-520 -- posted image.
Trunk shot
Close up in trunk
dwarren
Posted: March 20, 2007 at 6:21 PM / IP Logged
Looks like a well built box, but did you forget the carpet?
aznboi3644
Gold - Posts: 2,600
Posted: March 20, 2007 at 10:14 PM / IP Logged
its not done yet...i only had enough time to finish up the box then my brother had to leave to go back to IU
Next time he comes down I'm either gonna paint it or carpet it
stevdart
Platinum - Posts: 5,816
Posted: March 20, 2007 at 10:40 PM / IP Logged
I don't know, dawg...(Randy Jackson)...that slightly offcenter woofer cutout looks kinda odd.  I think I know WHY it might be that way, but the internal construction doesn't translate beautifully to the outer finished look.  Top spacing looks a little off from bottom spacing, as well.
(...again, Randy)...It doesn't do anything for me tonight.
aznboi3644
Gold - Posts: 2,600
Posted: March 20, 2007 at 11:07 PM / IP Logged
well steve...if you are thinking that the woofer is not centered because of the inner divider than you are correct.
Looks kinda weird cuz its not centered but it sounds good.
Steve, what do you mean the top spacing looks off from the bottom spacing.
And I do not think of myself as a professional or anything...just a hobby
stevdart
Posted: March 20, 2007 at 11:48 PM / IP Logged
Sorry, that top/bottom sub spacing probably appears like that because the car is partially blocking the bottom part of it.  I didn't notice that.  And sorry to be critical, but I just watched American Idol so I'm in the mood.  ;)
All people see is the outside appearance.  This subwoofer could convey a better sense of balance and harmony with a different look on the face.  I would experiment with slotted ports or something to try to achieve a prettier face on this box.  This, for a quick example, has the same offcenter woofer but the design of the ports takes the eye away from the asymetrical spacing.  It encourages the focus on other things:
KarTuneMan
Platinum - Posts: 7,056
Posted: March 21, 2007 at 11:56 AM / IP Logged
I hate to come off like an idiot, but.....whats an ABC box?
dwarren
Posted: March 21, 2007 at 12:43 PM / IP Logged
Already Been Constructed
Already Been Carpeted
Already Been Cleaned
Already Been Caulked
Already Been Cloned
Or
Aperiodic Bi-Chamber, it's supposed to be the best of both worlds with great output in the lower frequency ranges and still be smooth in the upper regions.
KarTuneMan
Posted: March 21, 2007 at 12:52 PM / IP Logged
Thank you for that very important educational information.....lastest build, mtx mzs1204, ps2-520 -- posted image.
dwarren
Posted: March 21, 2007 at 1:04 PM / IP Logged
Oh no worries, I had to search for the answer myself. It was just amuzing.
