gm sl2 users
johnmax
Copper - Posts: 131
Posted: April 05, 2007 at 9:37 PM / IP Logged
Any of you who have been using the GM-SL2 on  full size suvs and pickups and have been having the dead battery issues...
Has anyone tried the fix posted on their site about adding a 1k resistor to ground on the purple data wire? I thought I finally found a good module to use until all these damn dead betteries. Would like to see if anyone else has had good results with this fix before I go back to that module.
Platinum - Posts: 12,488
Posted: April 06, 2007 at 7:09 PM / IP Logged
Never had an issue with them draining. What version numbers do you have ?
johnmax
Copper - Posts: 131
Posted: April 09, 2007 at 4:13 PM / IP Logged
They drain on 1.0 thru 1.8. Pretty much on full size suvs and pickups. Every time there is a new revision they say its fixed, but its not. Now they post a fix with a resistor on the data wire. I'm not too keen on adding resistors to ground on the vehicles data wire.
dswift
Copper - Posts: 396
Posted: April 10, 2007 at 6:20 PM / IP Logged
there is a fix for that. Version 1.8 has the fix. Do you guys use the Idatalink stuff?
"dont ground out!"
johnmax
Copper - Posts: 131
Posted: April 10, 2007 at 8:45 PM / IP Logged
1.8 still has the problem. Here is a link to their fix: https://ifar.ca/download.php?productmanualid=492
Posted: April 10, 2007 at 10:47 PM / IP Logged
iDatalink we use as well as the Fortin modules. It's pretty good modules and easy to work with the new 232 port.
robmar
Posted: April 12, 2007 at 9:33 PM / IP Logged
i only had one truck with this problem
i was told three times that they had it fixed put three differnt versions in
only to jerk them all out and make my customer happy with a xko1
and sent back all the other gmsl1 i had
