interfacing remote
4wslude
Member - Posts: 9
Posted: April 09, 2007 at 8:30 PM / IP Logged
I have recently got a compustar 1 way alarm install and my car comes with factory keyless entry originally. How do I interface it so I don't have to carry 2 remotes all the time
noob
KarTuneMan
Platinum - Posts: 7,056
Posted: April 09, 2007 at 8:42 PM / IP Logged
when your done you will NOT carry the O.E. remote!
4wslude
Member - Posts: 9
Posted: April 09, 2007 at 9:13 PM / IP Logged
Yo this doesn't help much
noob
mikvot
Gold - Posts: 1,043
Posted: April 09, 2007 at 9:19 PM / IP Logged
Your original post is weak, you need to list the year, make ,and model of the vehicle, and the exact model of the system going into the car...and exactly what you mean by "interface".....then we can help.
4wslude
Member - Posts: 9
Posted: April 09, 2007 at 11:03 PM / IP Logged
It's a 98 civic sedan and the model of the alarm system is cm3300 compustar 1way
noob
enice
Silver - Posts: 857
Posted: April 10, 2007 at 12:05 PM / IP Logged
When I checked on Directechs it did mention that the factory alarm can only be disabled via remote.  That may be the reason why they told you to keep both remotes together.
peterubers
Silver - Posts: 706
Posted: April 10, 2007 at 12:59 PM / IP Logged
hmm... the info i have doesn't mention anything -
12 VOLT CONSTANT  WHITE (+)   IGNITION SWITCH HARNESS
 STARTER BLACK/ WHITE (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 YELLOW (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 WHITE/ BLACK (+)  IGNITION SWITCH HARNESS
 KEYSENSE N/A
 PARKING LIGHTS ( - ) N/A
 PARKING LIGHTS ( + ) RED / BLACK (+)  IN DRIVERS KICK PANEL
 POWER LOCK GREEN / WHITE (TYPE B)  @ BLUE PLUG IN DRIVERS KICK PANEL
 POWER UNLOCK GREEN/ ORANGE (TYPE B)  @ BLUE PLUG IN DRIVERS KICK PANEL
 LOCK MOTOR WIRE WHITE/ RED (+)  IN DRIVERS KICK PANEL, at DOOR HARNESS
 DOOR TRIGGER LIGHT GREEN/ RED (-)  LOW IN DRIVERS KICK PANEL
 DOMELIGHT SUPERVISION LIGHT GREEN/ BLACK (-), Requires Part #775 Relay  IN DRIVERS A PILLAR
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN BLUE to GRAY  @ STEERING COLUMN HARNESS
 TACH BLUE, See NOTE *1  @ TACH TEST CONNECTOR
 WAIT TO START LIGHT N/A
 BRAKE GREEN / WHITE (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  N/A
 ANTI-THEFT N/A
The search function is your friend.
4wslude
Member - Posts: 9
Posted: April 10, 2007 at 4:49 PM / IP Logged
Thanks peterubers.  I guess I needed to tap into POWiER LOCK AND UNLOCK When Armed and Disarmed the alarm system with my compustar remote
noob
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
