bass, radiator
barb_alone
Member - Posts: 7
Posted: April 20, 2007 at 8:05 AM / IP Logged
I want use 2 12inch bass and radiator...
but how can ý fix all of them ý don't know
jlaudio 12w6    I fix this bass
I want to use this 2 bass with radiator but ý don't know box parameters
how much lt bass box one of them ........
can you help me
ý want to use component morel elate 9.3 & 9.2 actif   ý want to use one zapco cd650.6 and one 1000.4 for component...
DYohn
Platinum - Posts: 10,741
Posted: April 20, 2007 at 8:23 AM / IP Logged
I think you'll get better results with a 12W6 in a ported enclosure of about 1.5 cuft (43 liters) tuned to 33 Hz than you will trying to use a passive radiator.  You could download something like Unibox and try modeling the woofer in a PR alignment.
Good choice on the Morel Elates, by the way.
haemphyst
Platinum - Posts: 5,059
Posted: April 20, 2007 at 10:45 AM / IP Logged
Passive radiato systems are typically HUGE! As an example, I have an Aura 10 with a 15" PR and it takes 2.2 cubic feet, NET! Very close to 3.5 cubic feet gross. (after bracing, external enclosure measurements, and driver/PR displacements) Sure, it's tuned to 22Hz, but still! bass, radiator -- posted image. Having tried them in the car, I find they are not very suited to the automotive environment. Two 12's with 12" PR's might end you in the vicinity of 6 to 10 cubic feet easily!
If you can provide the specifications for the PR you are considering, (Vas, and Fs - also, I'll need to know if additional mass can be added to it) I'll plug the numbers into JBL Speakershop, and see what I can hash out, also.
I also echo the sentiments of DYohn on the Morel setup, but I also send a nod toward the Zapco amplification. VERY nice choices.
It all reminds me of something that Moličre once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
barb_alone
Member - Posts: 7
Posted: April 23, 2007 at 2:17 AM / IP Logged
I know ported box diameter
but I don't know use with radiator my box lt?  and how cm al of part like 35x24x56 = .....lt
How can I learn the box extent and a photo
and which radiator use on my box ....and which extant
I don't want use ported box I want use with radiator box
because now I use ported box.....
barb_alone
Member - Posts: 7
Posted: April 23, 2007 at 2:18 AM / IP Logged
and how can I download Unibox and try modeling the woofer in a PR alignment
barb_alone
Member - Posts: 7
Posted: May 02, 2007 at 9:54 AM / IP Logged
help please
my system is also finish I fix comp. and 2 ampli....
but I can't fix my bass
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
