12 l7 and audiobahn a8002v
gr8snk
Posted: April 20, 2007 at 2:33 PM / IP Logged
I have an Audiobahn A8002v amp and (1) "12 KICKER Solobaric L7 w/ 2ohm DVC's . Which is the best way to wire this sub? Is it best to wire each voice coil separately to run 400 watts x 2 @ 2ohms or bridged 800 watts x 1 @ 4 ohms?  Is there an advantage with either wiring option or just basically the same?
aznboi3644
Gold - Posts: 2,600
Posted: April 21, 2007 at 3:33 AM / IP Logged
2 ohm stereo and 4 ohm bridged are going to be the same output. with stereo mode having a slightly better damping factor( amps control of woofer cone motion)
sedate
Silver - Posts: 1,173
Posted: April 21, 2007 at 5:48 AM / IP Logged
If all the channels are running at the same impedence, why would this be?
aznboi3644
Gold - Posts: 2,600
Posted: April 22, 2007 at 7:13 PM / IP Logged
This can explain it a lot better than I can
http://www.classic-audio.com/marantz/mdampingfactor.html
