remote start clifford matrix 50.5x
runforfuncc
Posted: July 01, 2007 at 3:59 PM / IP Logged
I have a 2006 Hyundai Sonata that I am installing a Clifford Matrix 50.5x in. Everything works fine (door lock, unlock, truck release. etc) except when I double press the remote start button on my remote, nothing happens. No relays click, and the transmitter doesnt beep at me to either tell me its remote started or that it didnt recieve the transmission. I have connected the neutral safety switch (BLACK/ white) as well as the remote start activation input (WHITE/ blue) to a ground. Is there something Im missing? Anyone have any suggestions? I havent connected my second ignition, which I will, but wouldnt it still try to remote start and then maybe shut back down? Any help would be greatly appreciated.
enice
Silver - Posts: 857
Posted: July 01, 2007 at 4:18 PM / IP Logged
Remove the WHITE/ blue wire to ground and try it
captainzab
Silver - Posts: 606
Posted: July 01, 2007 at 5:08 PM / IP Logged
leave your key in, in the "off" position
have your hood closed (or remove the hood wire)
ground your neutral safety wire (BLACK/ white) (make sure the wire is actually getting ground at the brain, the wire might be cut somewhere)
you shouldn't be using the WHITE/ blue activation input wire at all, cut it and tape it
reprogram tach
now try to remote start. you should atleast hear it try to start (or some clicking noise)
Note: You Always Dont Get What You Pay For.
runforfuncc
Posted: July 01, 2007 at 6:01 PM / IP Logged
Tried both to no avail. :( The transmitter shows that I am sending but it shows that the alarm is recieving. Which is weird because the transmitter isnt making the 3 double chirps to tell me the alarm didnt recieve the transmission.
