loc
noob555
Member - Posts: 25
Posted: July 08, 2007 at 3:46 PM / IP Logged
To install a LOC do you splice the speaker wires to the corresponding wires on the LOC then plug the RCA cables to the LOC then to the amp?
DYohn
Platinum - Posts: 10,741
Posted: July 08, 2007 at 3:52 PM / IP Logged
Yep!  Be sure to read the operating manual if one came with your LOC as there may be a gain adjustment you must take care to set properly.
noob555
Member - Posts: 25
Posted: July 08, 2007 at 5:12 PM / IP Logged
ok thanks..and when i splice the speaker wire what do i do with the other bit of wire that i don't use, do i just leave it?
stevdart
Platinum - Posts: 5,816
Posted: July 08, 2007 at 9:07 PM / IP Logged
Yes, leave it.  Make sure the soldered connection is well taped as well as any terminal ends that have been disconnected.
noob555
Member - Posts: 25
Posted: July 08, 2007 at 9:23 PM / IP Logged
alright, thanks.
noob555
Member - Posts: 25
Posted: July 09, 2007 at 1:45 PM / IP Logged
Do you need to power the LOC somehow?
sarcomax
Copper - Posts: 276
Posted: July 10, 2007 at 11:58 AM / IP Logged
Only if the instructions tell you to. Did the instructions tell you to? If they did, then you do, if they didn't, then you don't. You probably won't have to.
noob555
Member - Posts: 25
Posted: July 10, 2007 at 12:29 PM / IP Logged
k thanks.
noob555
Member - Posts: 25
Posted: July 11, 2007 at 4:19 PM / IP Logged
Do LOC's usually come with a remote 12v lead?..and if they do don't they need to be powered some how?
DYohn
Posted: July 11, 2007 at 4:46 PM / IP Logged
There are several types.  Some are powered.  What is the make/model of your LOC?
