electric aerial
Evansturbo
Member - Posts: 7
Posted: July 21, 2007 at 4:46 PM / IP Logged
i want to use a electric aerial to push up a monitor on the dash but i can only find fully automatic ones to do this, i want to put it on a switch like the switch used for electric windows and just pop up the monitor about 6 inches using the aerial  is it possible to do this using a fully automatic aerial or will i have to contiue my search for a semi auto matic one. cheers mark
CutDog504
Silver - Posts: 643
Posted: July 21, 2007 at 6:59 PM / IP Logged
What the hell is an aerial?
Ween
Platinum - Posts: 1,368
Posted: July 21, 2007 at 7:48 PM / IP Logged
that is also known as an antenna.
you can wire a fully-automatic antenna to work semi-automatically (manually operated)
mark
Posted: July 22, 2007 at 8:12 AM / IP Logged
The colonial (ie from England's oldest colony) means antenna! Better to use window motor, or  custom from RS etc. switched antennae unknown for last 20 years.
