Window Roll up Factory alarm
itr778
Posted: May 26, 2002 at 10:27 PM / IP Logged
I was wondering if anybody did a Window Roll up on a Factory Alarm on a Acura Integra 2001??  I"m not sure which wire to tap into for the negative pulse..
thanks..
Big Dog
Gold - Posts: 1,265
Posted: May 29, 2002 at 2:37 PM / IP Logged
Hey itr778,
Don't use the switch wires for window roll-up because there is no way to time the duration which would depend on how high or low the window is.  Instead use a window roll-up module which senses when the window is up all the way and of course disconnects the current to the motors.  This is much safer also if an arm is in the way.
The colors for the drivers motor are RED / blue and RED / yellow
front passenger are blue / YELLOW and blue/green
left rear are green and GREEN/ YELLOW
right rear are YELLOW /GREEN and yellow
all these can be found in drivers door.
 Window Roll up Factory alarm -- posted image.
Prepare your future. It wasn't the lack of stones that killed the stone age.
itr778
Posted: May 30, 2002 at 5:54 PM / IP Logged
I have a window module.. I know the colors of the wires to tap into.. i just need the wire to tap into for the negative pulse which tirggers the window module..  '
thanks
Big DOG>..
Big Dog
Gold - Posts: 1,265
Posted: June 03, 2002 at 1:19 PM / IP Logged
Hey itr778,
In that case what brand is your window module?  Most of them require an "ARMED" pulse from the brain,  it could be the same wire that you're using for your stater kill.
