de pinning pioneer connectors
dpaton
Copper - Posts: 141
Posted: August 21, 2007 at 10:01 PM / IP Logged
Specifically, the power/speaker connector on a DEH-P880PRS. I'd like to de-pin the speaker outputs, but for the life of me, I can't figure out where the secret tab is to release the connector pins without damage. Anyone have a suggestion? Preferably with pictures?
This is not a sig. This is a duck. Quack.
Platinum - Posts: 13,726
Posted: August 27, 2007 at 6:43 AM / IP Logged
I am not familiar with the plug on that particular unit, but if you post a few close-up pictures maybe I can help.
outtaluck72
Copper - Posts: 155
Posted: August 27, 2007 at 12:22 PM / IP Logged
you need a really thin blade flat head screwdriver, like a jewerlers screwdriver. looking at the face of the connector there is a tab that is up in the terminal holding into place. you need to take the flat head and pull down on the tab, while the tab is down pull on the wire to pull the terminal out. if you feel some resistance push the terminal back in as far as it will go and try pushing down on the tab again.
sorry no pics.
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
