good amplifier for a eclipse sw8122 dvc?
shagdrum
Copper - Posts: 68
Posted: September 18, 2007 at 9:31 PM / IP Logged
I have an Eclipse SW8122 DVC 12 inch subwoofer, and the amp I currently have is not powerful enough for it. I have an Eclipse CD8052 headunit that has 8 volt pre-outs. Each voice coil on the subwoofer is 4 ohms and the subwoofer will be wired in parallel so the amp will see 2 ohms. The subwoofer is rated at 500 watts RMS and 1000 watts MAX, but from what I have heard these subs are "underrated".  My main focus is on SQ, but having a little extra SPL would be nice too.
Basically I need an amplifier that meets the following criteria:
*up to 8-volt input sensitivity
*500 watts RMS (or better) at 2ohm
*2ohm stable
*good SQ
Any recomendations? Specific amps, or brands I should look at?
Thanks in advance for any replies.
haemphyst
Platinum - Posts: 5,059
Posted: September 19, 2007 at 11:06 AM / IP Logged
The Alpine PDX1.600 would fit that bill quite nicely.
shagdrum
Copper - Posts: 68
Posted: September 19, 2007 at 6:42 PM / IP Logged
Thanks for the reply!!
What is the max wattage at 2 ohms on that amp?
haemphyst
Posted: September 19, 2007 at 7:12 PM / IP Logged
600RMS at 4 ohms or 2 ohms
shagdrum
Copper - Posts: 68
Posted: September 19, 2007 at 11:01 PM / IP Logged
so...1200 max at 2 ohms?
aznboi3644
Gold - Posts: 2,600
Posted: September 20, 2007 at 12:11 AM / IP Logged
max is a number that is made up...doesn't mean anything
I gave a 200 watt 25 dollar sub 3000 watts for a couple seconds and it lived...doesn't mean that it is rated for 200 watts rms and 3000 watts max
haemphyst
Posted: September 20, 2007 at 9:53 AM / IP Logged
It's also a Class D amplifier. Don't worry about max power, ever. Forget what ANY manufacturer tells you about max numbers, they'll just get you in trouble. Alpine doesn't give a "max" power rating, so your guess is as good as mine.
That 600 watt Alpine will be a perfect match to that woofer.
shagdrum
Copper - Posts: 68
Posted: September 20, 2007 at 2:00 PM / IP Logged
sounds good, thanks
shagdrum
Copper - Posts: 68
Posted: September 20, 2007 at 7:13 PM / IP Logged
Any links to any reviews on the  Alpine PDX line of amps? I am considering replaceing my Eclipse XA4000 4-channel with an Alpine 4 channel from this line so they match. Is the PDX line known for its sound SQ? I have never used Alpine before, myself. Mostly Eclipse and Clarion.
haemphyst
Posted: September 21, 2007 at 2:07 AM / IP Logged
I'm a convert... I had a complete Eclipse system before, and it's now all Alpine amps...
Look up some of the threads on me, (they'll be the long ones, I think) I know there is a personal review of the 4.150 in there, somewhere!
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
