code alarm keyless entry upgrade system
bigaus
Posted: September 20, 2007 at 1:25 AM / IP Logged
Hi, first time poster and, if you don't mind... a question already.
Had an alarm installed by Toyota dealership on a 2008 Highlander. It is a Code Alarm, but no model number is stated on the owners manual. It just say "Keyless entry upgrade security system", although it appears similar to CA330 owners manual.
Anyway, being a fool I played with the alarm and now it is messed up. Tried to use the CA330 installation manual to fix but didnt work since it seems slightly different.
Would anyone have an installation manual for my alarm...or know what model my alarm is? Live a long way from dealership so not worth going there.
Thanks!!!
Twelvoltz
Platinum - Posts: 2,384
Posted: September 20, 2007 at 7:52 AM / IP Logged
What exactly is "messed up" about the system?
installmarc
Copper - Posts: 49
Posted: September 20, 2007 at 11:11 AM / IP Logged
the model number shouldbe on a white sticker on the brain
bigaus
Posted: September 20, 2007 at 3:14 PM / IP Logged
The programming is "messed up".
Before the alarm would arm after 15 secs (1 press) or immediately (2 presses), then disarm after 1 press.
Now, the starter cut-out switch arms itself after a certain period, and the remote will not disarm. Need to insert key and press override to start.
init
Copper - Posts: 93
Posted: September 21, 2007 at 9:34 PM / IP Logged
AFAIK, CA makes OE systems for Ford and Chrysler but not Toyota, could be wrong tho
I'm not a professional installer. But I did stay at a Holiday Inn Express.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
