99 F250 diesel, python 990
fords4life
Posted: September 26, 2007 at 9:09 PM / IP Logged
I just picked up a Python 990 for my 99 F250 (diesel).  I am crazy to try and do it myself?  It looks a little intimidating with the amount of wires but is it easier than it looks?  Are any of the diodes or resistors required?  If I take it somewhere to get it installed, what should I expect to pay?  I'm located in San Diego CA if anyone wants to help out....
Nathan
fords4life
Posted: September 26, 2007 at 9:38 PM / IP Logged
Forgot to add that the truck has factory keyless entry.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 26, 2007 at 10:12 PM / IP Logged
If you have ANY experiance at all, you'll manage. It's a tight squeeze to work in though.
If you DON"T have an time under your belt.........well...... Consider your time, whats it actually worth?
fords4life
Posted: September 26, 2007 at 10:35 PM / IP Logged
Never installed an alarm before.  If it's a matter of just tracing down wires and making connections, I shouldn't have a problem with that.  I browsed through the install guide and it looks as though the only diode needed is for the wire coming from the "wait to start" light.  Is this the only one?
