electrical interference on power cables?
digdug18
Member - Posts: 23
Posted: September 28, 2007 at 7:20 PM / IP Logged
Will this work?
http://cableorganizer.com/metal-braided-sleeving/
I want to wrap my 4ga power line in it, to minimize the electrical interference when I run the line in my teg. Should I do the same thing to the speaker cables I'm running as well??
Andrew
haemphyst
Platinum - Posts: 5,059
Posted: September 28, 2007 at 8:29 PM / IP Logged
Work for what? You won't gain anything on power or speaker leads, and it'd be debatable as to whether you gain anything on signal leads. It'll certainly LOOK cool, though.
digdug18
Member - Posts: 23
Posted: September 28, 2007 at 9:51 PM / IP Logged
Its gonna be under the carpet, you wont see it. I'm trying to cut the electrical interference that the power going through the 4ga power cable produces, and causes problems with the input cables of the amp, if run too closely together...
I'm not really concerned with the expense, I'll only need a couple of feet of it, where the input wires are close to the power wires by my passenger seat.
Andrew
audiocableguy
Copper - Posts: 630
Posted: September 29, 2007 at 9:50 AM / IP Logged
Are you trying to solve a problem or prevent one? Run your signal cables down one side, power down the other and if they cross do so at 90deg. If you have decent RCA cables you shouldn't have a problem.
DYohn
Platinum - Posts: 10,741
Posted: September 29, 2007 at 10:21 AM / IP Logged
Adding that product on a power wire will do nothing electrically useful in a car audio application.  It will help protect the cable from mechanical damage.
tcss
Silver - Posts: 1,623
Posted: September 29, 2007 at 11:49 AM / IP Logged
OK, one last time. Power cables do NOT produce noise when run near or over RCA cables.
There is no such thing as free installation!
dwarren
Posted: September 29, 2007 at 12:42 PM / IP Logged
Funny you say that, I just got through re routing RCA's on a Pilot that I had originally run with the power wire only to have terrible noise. So I draped a set of rca's from the deck to the amp and low and behold, no noise!. I ran the rca's down the center console away from the power wire and it proved to be noiseless.
tcss
Posted: September 29, 2007 at 1:17 PM / IP Logged
Dan you remember that thread right? I bet your original RCAs were run close to the car's ECU
techman93
Silver - Posts: 591
Posted: September 29, 2007 at 1:21 PM / IP Logged
Power wires will conduct some sort of noise due to the current running through it, sort of like a small magnetic field around the diameter of the cable. I would believe people when they tell you not to do something, it usually is because of lots of experience in the field. When installing audio systems I run power cable down same side that the battery sits and then signal cable down the opposite side. There may be special circumstances where that may not be an ideal set up but rule of thumb is at least a foot to two feet apart if running parallel to each other. A 90 degree bend if they do have to cross and make sure that you secure with duct tape to the floor under carpet.
dwarren
Posted: September 29, 2007 at 1:46 PM / IP Logged
Perhaps, as they did run under the dash, but I didn't see an ECU or BCM's as far as i can remember...How can I forget that thread!
What ever happened with those Focal's?
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
