alarm keeps going off, rs 560
eagerinsight
Member - Posts: 20
Posted: October 01, 2007 at 6:31 PM / IP Logged
No I did not install the diodes with the red line through them.
eagerinsight
Member - Posts: 20
Posted: October 01, 2007 at 6:35 PM / IP Logged
Should I isolate any other wires tapped into the BCM?
jmsounds
Copper - Posts: 99
Posted: October 03, 2007 at 1:28 PM / IP Logged
i had the sam problem with a dodge durango what i did i put a relay between the door pins isolated and the the alarm it work great just figure out the relay if
you have the diagram for the relay
jmsounds
jose
eagerinsight
Member - Posts: 20
Posted: October 06, 2007 at 4:38 PM / IP Logged
Would isolating the door triggers cause a check engine light? After I installed the diodes I get a check engine light, I'm going to have the code read on Monday, but I was wondering if anyone has seen a similar problem???
