how to factory disarm, 03 dodge stratus
tangoboyz
Member - Posts: 8
Posted: October 08, 2007 at 4:36 PM / IP Logged
I've done some searching around and I see many trunk release setups require a diode.  Does anyone know if mine does?  Could this be my problem.
profuse007
Gold - Posts: 2,015
Posted: October 08, 2007 at 6:34 PM / IP Logged
Coupe*(for some odd reason this vehicle has two diff diagrams for body types.)
Key Sense          WHITE/ GREEN          (-)          IGNITION SWITCH HARNESS
Trnk Release          BLACK/ WHITE          (REVerse polarity, aka 5-wire)          CONNECTOR C4, PIN1 @ BCM
     Alarm Disarm          ORANGE          (-)          DRIVERS KICK PANEL IN THE SAME HARNESS AS THE LOCK WIRES
__________________________________________________________
     Module 1          BCM - BODY CONTROL MODULE IS ATTACHED TO THE FUSE/RELAY BLOCK AT THE END OF THE DASH ON THE DRIVER SIDE
     Module 2          PCM - POWERTRAIN CONTROL MODULE IS LOCATED BETWEEN THE AIR FILTER BOX AND THE POWER DISTRIBUTION BOX ON THE DRIVER SIDE OF THE ENGINE COMPARTMENT.
For whatever reason, disarm is not valid, try the keysense wire for disarm.
Houston,TX
profuse007
Gold - Posts: 2,015
Posted: October 08, 2007 at 6:42 PM / IP Logged
sedan
FACTORY ALARM DISARM       LIGHT GREEN/ ORANGE (+) See NOTE *4       @ BCM, Connector C4, Pin 4, See NOTE *3
link to some note
__________
do not need any diode for trunk release
Houston,TX
