Autopage 750 LCD
Hazardless
Posted: February 19, 2003 at 11:03 PM / IP Logged
As i was installing it yesterday I noticed that after the majority of the wires were connected the system began to Arm itself after a little bit I read in the owners manual that this is a programmed feature and can be removed. well i havn't had time to get into it and remove it. The siren Has been disconnected because i don't really wanna make the neighbors mad while i'm installing it. Well I noticed that when the alarm goes "off" or in Panic Mode. the acual Computer makes a lot of Clicking Noises. Is this normal? I'm assuming it's a relay inside. Because i can also hear a relay under my hood Clicking with the Parking lights. Also one more question it's probably pretty dumb. But included in my Kit was a relay. I've read the instructions and i can not figure out were the relay goes? I'm knowlegable about electronics and wiring but not a genious i have a simi working knowlege of it. The only reason i am not having anyone install it for me is that they wanted about 200 bucks and would not install the remote start because i have a Manual Transmission..
drewbu
Member - Posts: 9
Posted: February 20, 2003 at 6:58 AM / IP Logged
hey...
I have the same ""noisy"" probleb i guess...
Well we bot tink it's relays .....
The relay you got with the alarm is to have starter kill (then armed can't start it, even with the key, good think to have).... if you need wiring diagram just ask ...
spfigura
Posted: April 17, 2003 at 5:06 AM / IP Logged
i would like to have the wiring diagram.
thanks.
steve.figura@mindspring.com
markwilliams
Member - Posts: 18
Posted: April 21, 2003 at 7:09 AM / IP Logged
I have the same alarm it clicks when the lights flash i believe it to be a relay. For example if i pull the negative terminal off the truck and put it back on it will click twice and the lights will flash twice.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
