UNGO ms2007 radar sensor install
N1njaTurt1e
Member - Posts: 10
Posted: February 20, 2003 at 6:12 PM / IP Logged
I recently bought an UNGO ms2007 security system for my car.  I also bought a radar sensor to go with the basic system. I was wondering if anyone had suggestions on how to hook-up the radar sensor to the system. I heard something about using diodes, does anyone know anything about this. Just in case it helps, I have a 99 Mercury Cougar. Thanks!
Platinum - Posts: 12,488
Posted: February 20, 2003 at 9:13 PM / IP Logged
You can wire in the trigger system to either the impact sensor ( if it has an external impact trigger wire ) or one of the door or hood triggers. Use a diode to isolate the sensor from the trigger wire that you are attaching it to. Have the cathode band facing the trigger wire if (-) trigger .
N1njaTurt1e
Member - Posts: 10
Posted: February 21, 2003 at 1:10 PM / IP Logged
Thanks for the info, I finally got my system today and I am planning on installing it next weekend. If I have any trouble I will put up another post.
ncollini
Member - Posts: 33
Posted: April 26, 2003 at 1:27 PM / IP Logged
Velocity, should the cathode band be facing the trigger wire on both the green and blue wires?, Do I need a diode for each sensor or just the proximity sensor?
