2003 f150, problem with subs
jrod83
Copper - Posts: 81
Posted: October 31, 2007 at 10:28 PM / IP Logged
A friend of mine has 2 w3v2's behind his seat. He has a premier headunit, alpine mrp-m650 amplifier. The problem is that when you turn it up, the subs cut out. The amp doesnt go into protect and the door speakers still play....At first i thought it was a problem with his ground but we grounded else where and we're still having problems. An installer at my work said it might be something about the RCA's but im not sure. you can play the music all day with the volume set to about 35. As soon as you hit 36 it cuts out. The gain is only at 3 clicks. I tested the wires right at the amp and it read 14.4.....what could be the problem????? can anyone help me?...
MECP Certified
I am the loudest and proudest member of the Fighting Aggies Class of '11 WHOOP!
SAW 'EM OFF!
still_walkin
Silver - Posts: 644
Posted: October 31, 2007 at 11:12 PM / IP Logged
If the subs cut out it could be the rcas or it could be the wiring in the sub enclosure . When the radio is turned up wires that aren't connected tightly when come lose. Are you subs on a seperate amp .
1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
jrod83
Copper - Posts: 81
Posted: October 31, 2007 at 11:38 PM / IP Logged
the wires in the enclosure are soldered...what do you mean about the RCA's?....is it just a bad wire?...or the terminals are bad?...
MECP Certified
SAW 'EM OFF!
still_walkin
Silver - Posts: 644
Posted: November 01, 2007 at 3:21 AM / IP Logged
if the wires in the box are  soldered then check the rcas add a new  set of  rcas and see what happens. i doubt its the speaker box termianl unless the springs on them are old unless its not spring loaded. but most of the time its a loose connection.
1993 sdv
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
jmelton86
Gold - Posts: 1,228
Posted: November 01, 2007 at 3:49 AM / IP Logged
Turn the gain all the way and see if it still happens. The gain may just be too high.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Platinum - Posts: 13,725
Posted: November 01, 2007 at 6:18 AM / IP Logged
When you checked the voltage at the amp, was the amp playing at volume 35?   What load is the amp seeing?   Do you have all 4 voice coils wired in parallel?  What ohm coils do the speakers have?   There is a missing designation on the description of the woofers.  W3v2-D#     the missing number will tell you what ohm the coils are.  What is the minimum load of that amp?
jrod83
Copper - Posts: 81
Posted: November 01, 2007 at 12:00 PM / IP Logged
the gains is at 3 clicks..its barely above minimum, and they are w3v2-d4...the minimum load is is 2 ohms on the amp...and i have them wire to 4...
MECP Certified
SAW 'EM OFF!
jmelton86
Gold - Posts: 1,228
Posted: November 05, 2007 at 6:03 PM / IP Logged
I missed the word 'down' in my post. Still, try it.
Big3 in 1/0G
1/0G to GTO14001
