1995 maxima remote start
JWorm
Platinum - Posts: 2,208
Posted: November 08, 2007 at 12:13 AM / IP Logged
Its impossible for trunk pop and trunk trigger to be on the same wire. What brought you to that conclusion?
morteza
Member - Posts: 25
Posted: November 08, 2007 at 10:05 AM / IP Logged
Trunk ReleasePurple / YELLOW (-) Driver's Kick Panel
Trunk PinPurple / YELLOW (-) Driver's Kick or BCM below Radio
^, unless they are identical and in the same location, which seems unlikely. what do i do?
profuse007
Gold - Posts: 2,015
Posted: November 08, 2007 at 12:31 PM / IP Logged
Test it, thats what you should do.
Houston,TX
morteza
Member - Posts: 25
Posted: November 11, 2007 at 8:17 AM / IP Logged
I installed a 791XVR without RS into a 1995 Nissan Maxima SE Manual. The problem is that, when disarming the alarm, the doors don't unlock and the receiver shows door open and the sensor (i think, shock sensor) goes off. It arms fine, i think maybe since the factory disarm is the same as unlock, its not on the right wire, or lost its connection. Also, the led still flashes after opening the door, as if the factory hasn't been disarmed.
moonliter
Copper - Posts: 322
Posted: November 11, 2007 at 8:52 AM / IP Logged
To unlock (GREEN/ YELLOW) required 2 pulses.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
