viper 5900, 00 dodge ram 3500 diesel
morg769
Posted: November 07, 2007 at 4:40 AM / IP Logged
2000 Dodge Ram 3500 Diesel
Installing a Viper 5900 SST and need to know where the WHITE/ blue wire remote start (-) activation input connects to or if it is used. Plug H1/10.
techman93
Silver - Posts: 591
Posted: November 07, 2007 at 6:35 AM / IP Logged
It doesn't get connected. It is for activating the remote start from another source.
morg769
Posted: November 08, 2007 at 1:43 AM / IP Logged
Hi
Can anyone give me the the relay satellite wire connection for a Viper 5900. Being installed in a 2000 Dodge Ram 3500 Diesel.
Purple I think it is Start output and go's to the yellow wire
Green I think it  is starter input  what wire will it connect to?
Red +12V  to Red or pink/black
Orange + Accessory output  to  BLACK/ orange
Pink+ ignition output to Dk. Blue
Pink/white not used
RED / white is it used?
Twelvoltz
Platinum - Posts: 2,384
Posted: November 08, 2007 at 7:07 AM / IP Logged
RED / White is necessary. The manual has not been updated to reflect that the RED / White is not jumpered at the relay pack anymore. Just connect it to either the red or pink/black with one of the reds.
Green and Purple are both part of the starter wire circuit. Cut your yellow wire in the vehicle and connect the green to the key side of the cut wire and the purple to the vehicle side of the cut yellow. This will provide you with both starter kill and anti-grind.
Pink/White probably will not be needed. I have come across some Dodge's that are picky and needed the second accessory powered. If for some reason the Check Engine light comes on or the A/C compressor or blower motor does not energize during remote start hook the pink/white to the BLACK/ white second accessory and program it to be an accessory output via the programming menu.
extreme1
Silver - Posts: 1,070
Posted: November 08, 2007 at 4:55 PM / IP Logged
IF YOU'RE NOt using the 2nd ign (pink/white) then the RED / white wire doesn't need to be hooked up.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
33up
Member - Posts: 19
Posted: November 10, 2007 at 5:53 AM / IP Logged
So if the Pink/White 200mA from the 7 wire ribbon is programmed to be an accessory trigger then the heavy gauge remote start relay Pink/White 2nd ignition output will become a 2nd accessory output?
extreme1
Posted: November 10, 2007 at 11:10 AM / IP Logged
yes, however I've never needed to hook up second acc in those trucks ever.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
