99 explorer getting a dei alarm/starter
sickstyles
Member - Posts: 34
Posted: February 22, 2003 at 11:05 AM / IP Logged
im installing an alarm/remote starter in a 99 explorer sport. the wiring info from this site says there is a courtesy light under the dash that im splicing off for the door trigger. there is no light under the dash! any idea what wire i can splice into for the door trigger?
Bnluis
Silver - Posts: 578
Posted: February 22, 2003 at 2:13 PM / IP Logged
Yes a light blue \ white wire in the kick panel  or high above the kick panel. this wire will catch all doors and liftgate without a delay. also you will find a yellow \ black in kick panel connect  your domelight wire from DEI alarm ( black\ white ) to activate pod lights and domelight when you lock and unlock. If you want to do priorty door locks all you need to do is run wires to the anti-theft unit at the left rear quarter panel there you will also find the door trigger wire. Good luck. Don't use the the positive door trigger it will set alarm upon remote starting. if you have any question sen me a message
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Bnluis
Silver - Posts: 578
Posted: February 22, 2003 at 2:19 PM / IP Logged
I forgot to mention all the wires listed above are  ( - ) negative trigger
Luis
Sound Waves
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
