2001 honda civic drivers side door lock
Posted: December 03, 2007 at 3:21 AM / IP Logged
Yes as tedmond says you joined it correctly. Further to measuring, set DMM to ac, black probe to ground and red to blue wire (incidentally it's on the r/h side adjacent to suspension housing on r/h drivers) it should measure 3-6vac with engine runing, technically if ac is a sine curve you're seeing the top half and most ordinary DMM's won't catch this therefore set to ac. PS, I also use the blue wire.
