chevy, gmc 1500 wiring
ervie
Copper - Posts: 68
Posted: December 06, 2007 at 2:28 PM / IP Logged
When i looked at the wire info on this site it says
12v, starter, 3 ignitions acc. this is for both
On the astrostart site it says
For gmc: 12v, 2 starters, 2 Ignitions and acc
for chev: 12v, 1 starter, 2 ignitons.
the reason i ask is i have a 96 gmc to do on saturday and will be using an autostart 2451 and was wondering if i need to use any relays
for some reason i have a hard time wiring them up unless theres pics. So any help would be great
Twelvoltz
Platinum - Posts: 2,384
Posted: December 06, 2007 at 2:37 PM / IP Logged
GMC and Chevy have always been the same. I have NEVER seen a 96 GM truck with 2 starter wires. Where exactly did you find a chart that listed 2 starter wires?
You should not need any additional relays for that truck. Your system provides the jumper-selectable 5th relay correct. Set that 5th output to be ignition, make sure you power both ignitions and the first accessory (orange) and you should be good to go.
ervie
Copper - Posts: 68
Posted: December 06, 2007 at 2:43 PM / IP Logged
at work we have astrostart program. i have noticed its wrong quite offen.
thankyou for your reply.
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
