disable factory alarm input, 96 pathfinder
yoskeeze
Posted: December 08, 2007 at 7:56 PM / IP Logged
1996 nissan pathfinder.i have a prestige(audiovox) remote start.all works well except i am unable to bypass factory alarm to remote start.says yellow/black wire(from rem start) to lt.green wire at antitheft module.doesnt work.i have to unlock with remote then use remote start or else alarm will go off.yellow/blk wire is not hooked up now
Chris Luongo
Platinum - Posts: 3,746
Posted: December 08, 2007 at 8:06 PM / IP Logged
yellow/black is to be connected to the ignition input of another, aftermarket alarm, as indicated in the owner's manual.
The small BLACK/ blue makes a pulse before remote starting, and is used to disarm the factory alarm.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
