dome light supervision on 1999 silverado
whitextreme
Member - Posts: 16
Posted: December 11, 2007 at 6:34 PM / IP Logged
I currently have an Avital 4200 installed in my 1999 Chevrolet Silverado and I am looking to hook up the dome light supervision.  I just need to know what wire to tap into to do this and if it is Pos or Neg.  Thanks.
V8Sonoma
Member - Posts: 11
Posted: December 11, 2007 at 6:35 PM / IP Logged
Is this a 99 old body style(classic) or a 99 up style truck?
whitextreme
Member - Posts: 16
Posted: December 11, 2007 at 6:43 PM / IP Logged
Im sorry about that it is a new body style pickup
V8Sonoma
Member - Posts: 11
Posted: December 11, 2007 at 6:49 PM / IP Logged
You can use the drivers door pin wire.It is located in pin b4 in the bcm,or in the drivers side junction box,with the harness coming from the door.make sure you use a meter and verify.It is a negative trigger doorpin.
tedmond
Gold - Posts: 4,610
Posted: December 11, 2007 at 7:27 PM / IP Logged
some units dont have an internal domelight supervision relay. Wire up a relay and jsut connect it to your door trigger pin
85 - constant 12v
86 - dome light supervision wire form alarm or RS
70 - high current ground
30 - Door pin wire
whitextreme
Member - Posts: 16
Posted: December 11, 2007 at 7:43 PM / IP Logged
Ok and the BCM is under the the steering column correct?
V8Sonoma
Member - Posts: 11
Posted: December 11, 2007 at 7:51 PM / IP Logged
The BCM is located under the steering column.
whitextreme
Member - Posts: 16
Posted: December 11, 2007 at 7:54 PM / IP Logged
Thank you guys for the help
JWorm
Platinum - Posts: 2,208
Posted: December 11, 2007 at 7:55 PM / IP Logged
85 - constant 12v
30 - Door pin wire
You do not need a relay. The door pin wires at the BCM are low current. You can connect your domelight supervision wire directly to the drivers tan doorpin wire.
whitextreme
Member - Posts: 16
Posted: December 12, 2007 at 9:05 PM / IP Logged
Got it all wired up with a relay thanks guys, what fuse are you supposed to use I only had a 5 amp and I used it and it is working so I assume it is ok right?
