multimeter with beep at preset level
concepts99
Member - Posts: 24
Posted: January 26, 2009 at 4:46 PM / IP Logged
Is anyone aware of a portable multimeter that will beep when it gets to a preset level, for example, set to dc, it will beep when it sees 12 volts.
oneohm
Member - Posts: 9
Posted: January 30, 2009 at 8:05 AM / IP Logged
Sounds like you want a "Peak Hold" function. Look for that when shopping around. You set the meter to the range you want, then press peak hold. When you get a voltage level that hits the highest possible, it will save it to the display so you can see how high it went.
loneranger
Copper - Posts: 572
Posted: January 30, 2009 at 11:09 AM / IP Logged
Maybe he wants an audible indicator, instead of having to look at the display, for quick 12v verification.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
