2002 olds silhouette lighting issue
joelincoln
Posted: December 04, 2011 at 11:10 PM / IP Logged
does anyone know exactly what a multi function switch is? that is what the mechanic said is wrong with my wifes van?
the turn signal indicators on the dash are acting funny and the traction control system shuts down and the daytime running lights are funny as well.
any and all help would be greatly appreciated
if its too loud you must be too old
Posted: December 09, 2011 at 4:12 AM / IP Logged
Sounds more like a Body Control Module to me and or a major power supply problem or poor grounds after some body work.
The faults listed are not connected to each other apart from ignition feeds. Traction control has nothing to do with running lights.
1) Check ALL fuses, not visibly but with a DMM set to continuity.
2) Get someone to run diagnostics.
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
