is this diagram correct? lockup converter
tony_ss
Member - Posts: 20
Posted: April 25, 2012 at 12:59 PM / IP Logged
I want to install a lighted kill switch to my transmission lock-up convertor.
Right now, hitting the brakes electronically disengages the lock-up.
Below is the switch I want to add to prevent the convertor from locking up at all.
Would this work?
is this diagram correct? lockup converter -- posted image.
tony_ss
Member - Posts: 20
79 Monte Carlo
200-4R lock up overdrive transmission
tony_ss
Member - Posts: 20
Posted: April 25, 2012 at 1:05 PM / IP Logged
I would like to add that the first part is how its wired now, and works perfectly fine...
tommy...
Gold - Posts: 1,901
Posted: April 25, 2012 at 2:51 PM / IP Logged
Can you describe EXACTLY what this is for... Did a quick Google search, but just looking for a better description... Thank You!( the locking up convertor, not the switch)
M.E.C.P & First-Class
tony_ss
Member - Posts: 20
Posted: April 25, 2012 at 3:52 PM / IP Logged
I have a transmission with overdrive. When in OD, the convertor 'locks up' and essentially makes a 5th gear for hwy driving (lowers the rpms for better gas mileage)
The problem is, I'm in 4th gear a lot and it locks up instantly which causes the engine to lug when I'm going 55mph or less. So thats why I want to stop it from locking up until I'm on the hwy doing 60+.
tommy...
Gold - Posts: 1,901
Posted: April 25, 2012 at 4:24 PM / IP Logged
Thank You...
tony_ss
Member - Posts: 20
Posted: April 25, 2012 at 4:29 PM / IP Logged
So......
does that seem like it would work?
The brake switch is a normally closed one.. when you apply the brakes it opens the switch and breaks the circuit.
I need a switch that breaks the circuit instead of having to apply the brakes.
I don't want to use a simple interrupt, I need a lighted one...
So....?
tommy...
Gold - Posts: 1,901
Posted: April 26, 2012 at 8:15 AM / IP Logged
Looks good to me... I dislike commenting when i dont fully understand the other "Stuff" that goes with it... IE Transmissions are an Engineering nightmare, or so they say... : ) It reminds of a show i watched on the Transmission... Oy Vey... But, it does appear that your diagram will work as YOU want it to... Hope this helps...
tommy...
Gold - Posts: 1,901
Posted: April 26, 2012 at 8:18 AM / IP Logged
Why is the light of the switch important...? Is it to determine if the switch is engaged or not...? You did the wiring of the first diagram...?
tony_ss
Member - Posts: 20
Posted: April 26, 2012 at 10:59 AM / IP Logged
The transmission install shop did the wiring on the first diagram, and it works fine like that. I just want more control over the lock up with a toggle switch.
I like that its lighted so it reminds me that the lock up is 'on'.. plus at night it will be easier to see.
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
