Posted: October 27, 2012 at 2:44 PM / IP Logged
Posted: October 27, 2012 at 7:16 PM / IP Logged
Posted: October 28, 2012 at 11:28 AM / IP Logged
Posted: October 28, 2012 at 12:30 PM / IP Logged
Posted: October 28, 2012 at 2:36 PM / IP Logged
Posted: October 29, 2012 at 7:00 AM / IP Logged
Posted: October 29, 2012 at 7:13 AM / IP Logged
Posted: October 29, 2012 at 7:32 AM / IP Logged
Posted: October 29, 2012 at 7:48 AM / IP Logged
Wednesday, May 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
)The Black wire should go to a good chassis ground source.The Red wire should go to an ignition Accessory source. An Accessory wire will test as follows : OFF ( 0 Volts ) while vehicle is OFF or key in ignition switch at OFF position. ON ( +12 Volts ) with key in ignition switch at ACC & ON positions. OFF with key in ignition switch in START position.The Yellow wire should go to a +12V constant power source. This wire will hold memory pre-sets if they are volatile.
