Posted: July 16, 2013 at 3:23 AM / IP Logged
Posted: July 16, 2013 at 5:15 PM / IP Logged
Posted: July 20, 2013 at 7:43 AM / IP Logged
Tuesday, May 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Problem 1: The momentary on/off only turns it on...
Problem 2: the on/off button activates the led and warning buzzer when pressed.
I'm using 40 amp relays, an overkill I know but they came with wiring harnesses and diodes which make things a little easier to wire up.
Any ideas much appreciated :-)
Will this work?
