pushstart ignition?
mrsparkle
Member - Posts: 10
Posted: July 07, 2003 at 3:26 PM / IP Logged
Hi,
Just wondering if there's a way to rig up a push start ignition on a 99 Chevy Cavalier?
xetmes
Silver - Posts: 586
Posted: July 07, 2003 at 4:04 PM / IP Logged
yes, yes there is always a way. pushstart ignition? -- posted image.
Maxst
Silver - Posts: 866
Posted: July 07, 2003 at 4:40 PM / IP Logged
ya..get a catalog like jegs  and go to the race car section...there you can buy the switchs and stuff to do it...looks hard tho..
I need quality equipment, feel free to donate.
fakepete
Copper - Posts: 99
Posted: July 07, 2003 at 8:55 PM / IP Logged
All you need to do is add normally open pushbutton to the start wire on the key switch. Or if you wanted to disable the key start completly just cut the wire to the key switch and wire it directly to the pushbutton. I don't see why people want to use relays and 60A toggle switches all the time. All you need is a pushbutton.
Big Purds
Silver - Posts: 574
Posted: July 08, 2003 at 1:15 AM / IP Logged
I have a setup designed for a much older car, but I am sure it would be fairly easy to make work in a newer car as well...I use my alarm to activate the "accessory" position of the key via a relay...if you want a copy of this diagram I may be able to scan it for you...
let me know...
