New to mobile electronics. Have Q’s
mikeshonda750
Copper - Posts: 105
Posted: December 04, 2003 at 10:22 PM / IP Logged
Hello everyone!
Within the past few months our shop, which is an automotive repair shop, got turned on to the idea of installing remote starters and alarms. Having a great deal of knowledge and past experience with electronics (not with car audio/security) , i was nominated to be the install tech for any of the remote starters and alarms.  The first few dozen or so have been fairly easy, and now that we figured out some of the pay scales + extras + extra time to install for this and that its starting to smooth out a little bit.
First and foremost, electrical connections: Today i slid under the dash of an Astro van and discovered it had previously had a remote starter installed by a local car audo specialty shop, but was cut out of the vehicle when it was sold. At first i thought it would be a great thing because most of the needed wires were "marked" for me and i didnt have to peel back any tape and such, but further inspection of the previous install job showed its flaws. They used scotch locks on all the ignition/acc wiring and cut everything off short. The starter wire's insulation was stripped back so about 2 inches of bare wire was exposed and they simply wrapped the remote start wire around and through it and taped it up (not too good i might add). The rest of the locks were exposed and not taped in any way shape or form. My question is: Do most typical car audio places use these methods? Toss a scotch lock in, crimp it down and move on?
Im not a huge fan of scotch locks. They do limit the current that can travel through any given wire, they damage the wires and so on.
Next question would be: How much time is spent on most common typical remote start installs and alarm installs?  Does this include the wiring of needed relays for doorlock hook up? Does it include the costs of relays, resistors ect? If not, how much extra should be added for the relays/resistors/time spent wiring them in and mounting them securely?
Main reason why time is an issue (other than living in a gotta have it yesterday socitey) is because if the price remains the same, and extra time is needed to wire in extra's (such as relays or resistors) or drill holes ect. , profitability is decreased, and what was a great profit, simply becomes money exchanging between our customers and our suppliers/empolyees, which is better than loosing money, but also doesent help keep a place alive, just ties a bay up.
Back to electrical connections. I will admit it. I use butt-connectors on nearly everything. I use see-through connectors and crimp them down the right way, and depending on the size of the connecter, either use ray-chem(shrik wrap/tube) or a combination of liquid electrical tape and black electrical tape. I feel that my connections are rock solid and permenant. My questions is: Is this a common practice among car audio shops?  If so thats great, if not, how is it cost effective / time effective to crawl under the dash of a car with a soldering iorn and connecting numerous wires. Also, its not too easy to get a soldering iorn into alot of places without burning other wiring or getting delicate electronics too hot.
I have alot more questions, but its getting late and i have 3 to install tomorrow before noon. Thanks for your help guys! Im open to any suggustions and or comments.
Thanks!
NowYaKnow
Gold - Posts: 1,217
Posted: December 05, 2003 at 6:20 AM / IP Logged
Hey. I don't use scotch locks at all, and would never use them. I like the strip, poke, and twist method like you said you found in there. Strip the wire, poke a hole in the middle of it, put your wire through the hole like your threading a needle, and then wrap the rest of the wire around it. If done properly this method works great and is very reliable. A bunch of manufactures actually recommend doing it this way as well. Of course soldering is probably the best way of doing it but as you said sometimes there's just no way your getting a soldering iron to some wires..As far as speed I don't think it really takes much longer to solder the wires once you get in the habit of doing it. Butt connectors would work as well but I don't see the point in cutting all the wires just to put them right back together.
"How much time is spent on most common typical remote start installs and alarm installs?"
Typical installs usually take around 1 - 3 hours with the average falling into the 2 hour range for a nice job.
forbidden
Platinum - Posts: 5,353
Posted: December 05, 2003 at 12:57 PM / IP Logged
Scotch lok's - ewwww - who the hell made these things anyways, they should be brawn and quartered. While some people do the strip, poke and twist - tape, I will definitely not recommend this practice either. While it may work just fine right now in the time the joint will definitely deteriorate. Always solder the main connections for the power, ignition and accessory lines, there is always a way to do it. There is nothing worse than having to fix someone elses work (as you have found out). The quality of your work speaks more about you than you know, all it takes is one customer to go somewhere else and that installer either pronounces the install good or bad, as you have done above. So always solder the main wiring. To use butt connectors on the smaller wires like hoodpin and tach I can see, usually if I have the soldering iron out, I'll solder all the wires, and use heatshrink when you can.
Now why do I not do the strip,poke and twist - tape. Because problems with joints happen down the road. On a hot day that black tape might be nice and sticky, on a cold day it will be nice and brittle, over time that black tape connection will come loose leaving a twisted together joint. Next that joint has been vibrating away due to normal conditions present in all vehicles, it is only a matter of time before it comes loose, this causes all sorts of issues with remote starters that pass large amounts of current. Problems happen down the road, if you are prepared to warranty all those connections in the coming years, great go ahead and strip, poke and twist and hope the customer comes back to you and not your competitor, otherwise rest easy and confident that soldering has made the best permanent connection. Imagine if they built amplifiers with the strip, poke and twist method, yeesh.
Wiring in this method takes a little more time but yields a higher quality install, take some pictures of the methods desribed above in order to show a customer what the other shops have been doing, this is a great way to justify a better quality install that is worth the extra $.
Teken
Gold - Posts: 1,492
Posted: December 05, 2003 at 2:33 PM / IP Logged
I couldnt have said it any better, as it was stated by Forbidden.
The only thing I would like to suggest to you is this. Invest the time and resources to have the correct wiring schematics for each vehicle you are working on.
And above all else, varify all the information given with your DMM. You could do the same thing by using any web site which confirms your findings.
Like they say, be a wood cutter. Measure twice, cut once.
As for making connections, soldering is the only method in the field that will pass the test of time.
Regards
EVIL Teken . . .
NowYaKnow
Gold - Posts: 1,217
Posted: December 05, 2003 at 5:45 PM / IP Logged
"Next that joint has been vibrating away due to normal conditions present in all vehicles, it is only a matter of time before it comes loose"
I'm sure we can debate this all day, but just a few more common practices I would recommend. I also put a zip tie on top of my connections (usually only ignition wires) to keep the tape from coming undone and to keep the wires from touching each other to stop any type of short should the wires come through the tape. Once I wrap the wire through I close the "hole" I originally poked with a pair of pliers to sort of crimp the connection and tighten things up. I double tape all my ignition wires before adding the zip tie. Once that is done the entire harness of wires also gets a zip tie around it. You can pull on the wires and vibrate the wires all you want, they are not coming undone or rattling loose. Again I'm not trying to say soldering isn't good, it IS the best method, but there are alternatives that are reliable. Also I have yet to find a suitable cordless soldering iron that I like. Working on a car in the middle of a parking lot 3-400 ft from any outlet makes soldering a little more of a chore. Also stay away from that tape you see at the cheap tool shows @ 10 for a $1. It's that price for a reason.
Also to help with the original post. Not sure if all makes have this but Code Alarm has a list of all vehicles and an estimated labor time to install a product. You see one with a time of 4 - 5 hours listed you know there is a bit more work invovled and you could charge more for the job.
"The quality of your work speaks more about you than you know"
This is entirely true. You (Mike) being nominated install tech puts a little more pressure on you to do a nice job. Not to mention if your other installers see you doing hack jobs chances are they will pickup on your bad habits. Our industry is littered with hacks installing products for the short term not worrying about what will happen in the long term.
Best of luck,
Mike
mikeshonda750
Copper - Posts: 105
Posted: December 05, 2003 at 7:10 PM / IP Logged
Thank you all for taking the time to reply and add your advice and comments. Think I have a good grasp of everything, just having a horrible time juggling performance VS quality. Yes, i was the best possible quality out of my work, but as i have found recently, to accomplish this level of quality, I invest large ammounts of time preping and soldering connections and really, there are alot of places that a soldering gun will do more damage to the surrounding area than good to my connection. But soldering is not out by any means, just need to know either what your using to make these connections (what type of iorn) and or how can you be fast(er) at it? Im using a standard Snap-On A/C Soldering iorn with a long barrel on it.
As for wiring diagrams, i use DTI's "wirecolor" software to give me a general idea of where to find "these" wires, and from there its me and my DMM. Sometimes, such as when tracing down tach wires, or finding very specific door lock diagrams i will use our Mitchell On-Demand which is an excellent source for wiring diagrams, the DTI simply gives me a place to get started.
Pricing: Heh any ideas here? I know what our base pricing should be, but like today i had a dodge stratus 2.7 sedan getting a remote start+Keyless. I had to use resistors and relays on it for the door locks. Now the problem isnt charging for the relays, and the resistors are cost free nearly per customer, the problem comes in with the labor to wire up the resistors the correct way, and wire up the relays and find a place to mount them and so on.
The labor times would be excellent!! Will give me something to "shoot" for and i know that if it says 3hrs and im getting it done in 4-5, either im having a bad day or i need to be doing something differently.
Thanks again for all the pointers and tips guys!!
forbidden
Posted: December 05, 2003 at 7:33 PM / IP Logged
Get yourself a good butane soldering iron (Blue Point), it's small, has piles of heat and can fit into more places. Your time will speed up, don't worry about that, but never sacrifice the quality of your install, because the day will come that you will have to warranty it and spend more time to do it as you should have the first time. Usually I would charge an extra hour labour + shop materials + relays to add a power door lock kit to a remote start. If the vehicle used a negative trigger for the locks we usually do it at no charge (a good word goes a long way) Once you have done a couple more starters you will have all the basics down pat, once you have the trickier vehicles through the shop (new F350's, GM passlocks, any vehicle with a transponder.......) you will get a better idea of additional time, techniques, parts and costs.
mikeshonda750
Copper - Posts: 105
Posted: December 05, 2003 at 9:18 PM / IP Logged
Starting to get a better feeling about all of this. Hardest part of the entire job is when the salesmen walks out into the shop and asks "How much more time on that, the customer is on the phone" and im layin there trying to get it done and guestimate how much longer.
Another problem is figuring out a "good" time to tell the customer when it should be ready, then getting the car in only to find that it has positive door locks that require resistors and relays and tell the customer it will be an added hour or so to install this passlock2 bypass and hook up the door locks.
Think they are starting to realize that everything i have done so far has been totally different. Some just require relays, some just require resistors, some require both and some require none and the only thing that is about the same across the board is the remote start itself... none of the extra bypass equipment and keyless stuff.
How do you guys use your resistors and relays? Do you have them pre-wired in your downtime/sparetime and marked "Dodge Caravan - lock wire/Unlock wire" or "4 wire reversal"  so when there needed you simply solder in your few leads and away ya go.... or do it on an as needed basis?
Another thing we are considering would be DVD's and LCD's and such. Is it very profitable to be able to do these types of installs, or is it on a much higher playing field compared to remote starts and alarms? Im satisfyed with starts and alarms for now, but if its profitable, im open to it and will try anything a few times = )
Soldering equipment: Like i said, using a corded snappy long barrel gun. As Forbidden mentioned, a butane based iron. Which would be better and why? Considering http://buy1.snapon.com/catalog/pro_det.asp?P65=&tool=all&item_ID=66590&group_ID=787&store=snapon-store&dir=catalog as a cordless rechargable, or do you think this http://buy1.snapon.com/catalog/pro_det.asp?P65=&tool=all&item_ID=7141&group_ID=12178&store=snapon-store&dir=catalog would be better for my situation? or both?
Teken
Gold - Posts: 1,492
Posted: December 05, 2003 at 10:09 PM / IP Logged
That is the cordless soldering iron I use in the field, when a AC supply is not readily available.
Very good craftmenship, and feels very well in the hands for prolonged use. Also, if you're considering this tool, please spend the extra money for the entire kit which includes extra soldering tips and a sponge.
BTW: There are cheaper units to be found at the local auto parts / electonics stores.
Regards
EVIL Teken . . .
mikeshonda750
Copper - Posts: 105
Posted: December 05, 2003 at 10:52 PM / IP Logged
Yeah, nice thing about snapon/mac/matco is i allready have accounts setup with them and it makes it nice to get a quality peice of equipment and be able to make payments on it.
As is, a problem i have with using my gun inside the car is its bulky and requires an extra cord, and as most of you know, theres not alot of room on these floorboards for extra junk.
About the cordless: I love the idea over butane irons, but do they get hot enough to reliably use and, are there other models avaliable? snappy is about all i can find, nothing at radio shack, nothing at napa/advantage/az not even a craftsman model avaliable i can find.
Thanks for the info though! I dont mind spending the extra money to get something that will make me faster, make life easier and be generally safer.
Thanks!
Friday, August 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
