Wiring In '91 Lumina
jrs362
Posted: April 18, 2004 at 11:39 AM / IP Logged
Hi
already took out the facotry stereo and disconnected all wires from it. Going to install pioneer stereo. My problem is, the original wires are in the plastic "plugs" that fit into the old connections. Should i just cut the wires so that the plastic is off and then connect the original wires or is there a way im supposed to connect the new wires to the plastic pieces?
Any suggestions?
NINsane18
Copper - Posts: 103
Posted: April 18, 2004 at 7:56 PM / IP Logged
Never cut the factory harness. Go to Wal-Mart or any local stereo shop and get a wire harness to plug into the factory plugs. They are real cheap, and they make things a breeze.
Tim-May!
Dauber
Copper - Posts: 97
Posted: April 19, 2004 at 12:55 AM / IP Logged
As with the wiring harness that Ninsane18 said you should get, while your at that store grab a dash kit for your car as well, it will make your life alot easier and makes for a quicker install.
Kyle@Audio Obsession Sound
NINsane18
Copper - Posts: 103
Posted: April 19, 2004 at 5:16 PM / IP Logged
Good call Dauber, forgot to mention that.
Tim-May!
