rev limiter
trollman200
Member - Posts: 17
Posted: May 19, 2004 at 8:25 PM / IP Logged
does anyone know how to disable a rev limiter and if any what are the consequences?
athensdawgs81
Posted: May 20, 2004 at 9:08 PM / IP Logged
Aftermarket computer chip will disable the rev limiter and shouldn't cause anything bad to happen except that there is a slight chance that you may over rev the engine if you don't watch your tach. I twill also give more HP and better fuel mileage which is good with todays gas prices. One will ste you back $100 to $1000 depending on how much HP you want and the type of car. Try superchips.com.
thepyrofish
Member - Posts: 36
Posted: May 21, 2004 at 10:18 AM / IP Logged
I can understand wanting to disable the speed limiter (called a governor I believe), but what would be the purpose of disabling the rev limiter? unless you have done some engine work to enable the car to handle higher rpm's, what do you drive and have you modified the engine?
deviousjoker
Copper - Posts: 102
Posted: May 22, 2004 at 11:17 AM / IP Logged
the only thing bad will happen is you'll blow up your engine.  the rev limiter is there to avoid blowing your engine up. the govenor is there to control your speed not your rpms.
First Class MECP Installer
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
