Window Module....
eld101
Member - Posts: 43
Posted: September 01, 2002 at 10:29 PM / IP Logged
To start off, I have a 92 Prelude SI.  I also have the Sidewinder 6500ESP alarm/rem start.  I was thinking about adding a window rollup moulde like http:///.com/dll?ViewItem&item=1377689053
First...why there are 8 wires...I know there will be a +,-, - from aux channel, then 4 for the 2 windows.  What would the other wire go to?
Second, what color wires would I tap in the door?  Do I just tap the wires or to I actually have to cut them and wire the unit in between?
Lastly, will this unit work with my car and alarm?
Thanks in advance for your help!
Eric
Jason73
Posted: September 02, 2002 at 12:09 PM / IP Logged
Eric,
I'm not to sure about the sidewinder window control module but to be sure I would contact a local shop that carries this alarm and ask them or call Siderwinder. It might be another (-) input trigger that you can tie into the other (-)input trigger.Or you can purchase the DEI 520T (I think). It will work with any alarm that has a (-) output trigger. It's only about $30 or so and it comes with instructions. I use them in all my installs.
As for which wires to cut into, contact your local shop. They might have a program called MAID XL like I have. If I get time I will look up the color codes for you.
Also if the module you want needs a (-) input trigger to activate it and you have an extra ch. with a (-) trigger then sure it should work.
eld101
Member - Posts: 43
Posted: September 02, 2002 at 3:36 PM / IP Logged
Thanks.....does any one here have MAID XL?
mobiletoys2002
Gold - Posts: 1,050
Posted: September 02, 2002 at 5:12 PM / IP Logged
ok u have a reversal rest at ground window system and your colors are drivers side up is RED / blue,drivers side down is red\yellow passenger side up is blue / YELLOW,and down is blue/green.
christophe
Member - Posts: 34
Posted: September 02, 2002 at 5:14 PM / IP Logged
hey eld101,
On all window roll up window module (that I know of), you will have to cut the factory wire going between the switch and the motor. Therfore you have 2 wires to the switch and 2 wires to the motor for each power window you would like to control.
Left front window RED / yel and RED / blue
right front window blu/grn and blu/yel
hope this helps
eld101
Member - Posts: 43
Posted: September 02, 2002 at 8:55 PM / IP Logged
Thanks!
tekstyle
Member - Posts: 13
Posted: September 02, 2002 at 10:22 PM / IP Logged
2 wires goes to switch for both windows
2 wires goes to motor for both windows
1 wire for +12V and 1 wire for ground
1 wire for aux channel ( - input)
1 wire for ignition kill relay ( so it doesnt activate when ur ignition wire is hot or cold )
i forgot which side the ignition wire goes to, but i know this is correct bcuz i had it on my car, sold the car tho, but planning to do it to my new car
Saturday, January 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
