RF CD Changer in '97 Sable
macville
Posted: September 08, 2002 at 5:56 PM / IP Logged
I have been trying to install a SPS 6 disc RF cd changer in my 1997 Sable (With Mach audio sound system) and finally got the changer wired in correctly today (I'm pretty sure.) However, whenever the LCD controler is pluged into the RF unit the atnna. stayed down until I unplug it (plus the controler doesn't seem to work...) So...what do I have wrong? Is it that my controler is busted and needs to be replaced, or do I have something wired incorrectly?
Thanks,
Matthew Rogers
cpgoose
Gold - Posts: 1,098
Posted: September 09, 2002 at 6:13 AM / IP Logged
It's been a while, but don't you have to disconnect the antenna from the radio and plug it into the RF adapter....and then plug the RF adapter's plug into the radio's antenna input?
Not sure if that's what you did, but if you didn't that might be the problemo.
